1 - 2 of 2 Posts
hey got an AM coded gearbox where am uprating the clutch cross shaft with a bugpack urethane kit. am having trouble fitting the return spring and wonderd if sum1s already tried to fit this kit before and had any tips on fitting the spring
cheers again Mordie
Are you having trouble getting the spring onto the shaft and located, or is it another issue?
Basically you just have to lever it over with a big screwdriver or similar. Put the small end onto the step on the box and tap the spring and shaft up and then pull it back.
1 - 2 of 2 Posts
