*looks in his haynes manual*
if you look in the front engine section on the one i have it lists 1700 and 1800 models,
both stating the compression should be 100-135psi for the 1700 and 85-135 for the 1800, if you then look at the suppliment section at the back for the 2000cc engine it specs the PSI in Bar and then once again 85-135Psi with a maximum of 42psi difference between cylinders maximum and minimum found accross all cylinders.
hope thats what you wanted to know :hangloose
