Hi, I have a 2 litre engine fitted into my 72 bay and it will not stop popping on the 3rd and 4th cylinder side. I have checked for leaks, changed plugs, leads, checked timing several times, new cap, rotor arm and have even fitted petronix but it still pops! While being new to all this and learning fast I still can't seem to stop it from popping.
A more mechanically minded friend came over and suggested the carb be next on the list to check, a couple of years ago the carbs were set up by someone using a rolling road.
My friend wasn't to sure about how to check/clean/adjust the carbs (twin 40 dells). For a start one has a small u shaped pipe which blocks off 2 ports and the other one doesn't. Could a carb problem be causing the popping, could the idle jet be partly blocked, the float level too high or could it be running to rich/lean? Could it need balancing?
Are there any good threads, websites or books on checking/setting these carbs?
Thanks for any help
Thanks for any help
