I then decided I wanted a Karman Ghia, so put it up for sale, but on the way to being on display at the Volksworld show the engine caught fire!
I kept the car and decided to get the necessary work done and then put it up for sale again. But as quite often these things go, it started costing more than I thought and I was getting a bit carried away with getting all the parts for it, so I decided to keep it and make it into the kind of Beetle I always wanted! I was going for a high-tech streed-rod kind of style.
The body was bare-metalled, new heated channels were welded in, new front & rear quarter panel bottoms welded in, new spare wheel-well, '67 only rear valence and decklid, a genuine pre '67 bonnet fitted, the seams/guttering removed on the front quarters, new front beam with sway-aways and a front disc-brake conversion with new discs, pad and brake lines.
Hidden door hinges by Shane Powell were welded in, the rear air vents were welded-up and a high-level brake light fitted in place. A vent to get air into the engine was made going from behind the engine to under the car. The running boards are smooth fibre-glass ones from Wizard roadsters. The outside fuel-filler flap was welded up and the fuel tank is an early type with the filler neck on the tank. The fuel-filler cap was chromed. The bonnet catches were nickel plated and chromed. The bonnet hinges are polished billet alluminium. The tabs at the bottom of the headlight rims were removed for a smooth look. There are new Bosch sloping headlamp lens, rubber headlight seals and drain tubes + mk 1 Golf crystal headlights. The body was sprayed with House of colors candy turquoise over metallic turquoise. The doors had Renault Laguna oval-shaped door handles fitted which took many hours of head-scratching to be made to work! The respray + some of the body-work cost £4500 at the time!
T.B.C!
T.B.C!
