i have two speed wipers on my beetle and an electric washer pump
question is, if i apply a feed from the washer switch to connection 53 *** on the wiper switch/motor will that then wipe as i wash?
*** edit *** just noticed #53 is grounded when parked should it be 53b (High) ?
Discussion Starter · #2 ·
ok i've realised if i do the above then my washers will operate when ever my wipers are set to Hi, so if i switch a relay with the washer button then the wipers couldn't back feed to the washers and use the relay to flick wipe while i'm washing
does that sound right to anyone?
