A bit of nerdy, tech advice needed.
I've canti brakes on my singlespeed On One. I don't want to swap to V's.
I'm getting brake judder from the front brake. I know it's the brake hanger causing it.
The hanger is attached to the steerer tube, it's a high end part, but some of it is missing, so it's got a cobbled together stop. I think the judder is caused by the whole hanger vibrating. The steerer spacers are all tight, without causing stress.
Anyone got any suggestions for a vibration proof hanger for a steerer tube?
Alternatively, I could go with a hanger that attaches to the forks. Unfortunately, the forks aren't drilled for brakes, but the front face is drilled, probably a mudguard mount. It looks fairly low down the fork, near the open end.
I'm thinking of drilling through the rear of the fork and attaching the hanger. My concern is the mount will be so near the bottom of the fork, it may snap or bend the fork edge under heavy use.
Anyone got any suggestions? Are the forces likely to cause this to happen?
I don't mind spending time and (a bit of) cash on it.
Cheers.
Sol.
Cheers.
Sol.
