Did anyone put a servo into a 1303???
404 Views 3 Replies 3 Participants Last post by  psimitar
Hi i am in the middle of restorations of my 1303 and i'll put calipers all around , so i like to put a servo to give my more easy and soft braking , do anyone her did it
GONZO
http://erbie.fotopic.net
You can fit a remote servo, something like one off e.g. a bmw 2002.
One of the things on the list, just not got round to it yet.
I have already a subaru servo from a turbo one but not sure how to do it
well from what i can tell the remote system only works on single line master cylinders. so the master cyliner output goes to the servo and the servo output goes to the original T-piece that distributes the fluid to the brakes.
not sure if you have dual output master cylinder apart from how it would be mounted in a modern car ie the servo is between the brake pedal and master cylinder.
of course you will need to run a vacuum line from the engine manifolds to the servo aswell.
