Good point Glen.
I've been waiting to get an alternator kit before I mount the throttle body on the manifold, just in case there was a fitment issue. Today it arrived (I ordered it while rather inebriated and with a more gung-ho attitude than my normal cautious self!). No problems fitting it to the mock up engine I have, so I won't bore you with the details.
Anyway, this morning I turned my attention to the throttle body. Then I noticed, with a sinking feeling, that the rotation of the throttle spindle was the wrong way round.
So I took it apart to see what could be done. I really don't want to have to go on the search for a different one again!
Hmmmmm it does look like the butterfly can be fitted round the other way....
So I did.
That caused an issue with the throttle position sensor orientation. A quick modification to the spindle and I'm back on track. The only problem now was that the "wide open" position stop was the TPS limit. Not good.
I drilled out the centre of the, well, I don't know what it's called! This thing..
I modified a thick washer to fit the spindle and put both on the body in the orientationi need. I've only tacked the washer on for now just in case.
Then I drilled and tapped the old Wide Open stop to convert it into the new "closed throttle" stop. Now if I can't setup the Idle valve (I have a nagging feeling my ECU won't like the Nissan one) I can adjust the idle with a screw, like on a carb.
The bonus with this set up is that I now have an adjustable wide open stop. Dunno why I'd need to adjust it, but hey-ho!
I fitted a return spring I had so the butterfly snaps shut nicely.
Next I need to fabricate the connection to the cable, but I'll do that once I've finished the manifold. That will be another day now though.
