Hello,
I'm highjacking the aircooled forum, my watercooled VAG audi has a problem. When I squirt the windscreen with the washers and the main beam is on, the main beam changes to dipped beam plunging me into darkness.
I think it sounds like a bad earth, what do you peeps think?
(its normally dark when I remember it needs looking at! funny that)
D you have scarts that connect to the column? If so you need to take off and clean. Though I am an aircooled, I still run a long distance car. The scarts are usually at fault....R :coffeecup
Hard to diagnose at a distance, but any fault where one circuit interferes with another is usually a bad earth somewhere.
