1 - 8 of 8 Posts
ok looking at getting my carbs fitted up with a stock fuel pump but they both seem to have dual connections on them, see the diagram below can anyone advise me on which way they should be plumbed in?
From where your fuel line stops coming out of the fuel pump, you can add a 'T' piece and run each line to the larger opening on each fuel union on the carbs. The other openings can be joined together using another piece of hose or blocked as someone else stated.
you can get single inlet banjos for DRLA, that'll neaten the whole lot up. Try Eurocarb
1 - 8 of 8 Posts
