The gutters aren't "attached", they are 'formed' out of the seam where roof and side panels are pressed and welded together. Complex and time consuming to repair, hence the high price quote from your garage.
hello mate i have had mine done by my bros mate who is the mutts nuts... and beleave me if you have heart problems dont do it
i looked around for prices and all the ones i got i could have got a new van...or they would not take it on.. but mine was real bad you could lift the roof up.....ha ha
its not as easy as some my think all the panels you can buy dont fit the same.. night mere..
so really it would be more simple to fit a complete roof skin if its just spot welded around where the gutters are? im thinking of doing that on my bus as the gutters look mouse eaten in certain areas...
It's literally just rotted away at the roof under where the plate was spot welded on.
I'm surprised the entire lot hasn't caved in by now.
As said previously, i just need to cut a section of the roof out (Where the plate had been welded on top) and remove all the crap and then weld a new section in the length of the roof.
Thanks again for all the info everybody :hangloose
Not much disortion. I had a sore wrist by the time I had finsished as I spot welded every few inches all the way allong, each time waiting for it to coool down. I then spot welded in between again and again............ took ages, and eventually had a continuous weld.
I also put a flange in it using my air flanging tool and used cleco pins to to clamp it in place.
Volkszone Forum
