1 - 9 of 9 Posts
Have a F type case in our garage and considering getting parts together to do an engine build (with guidance of course) over winter.
Pretty sure it's a 1300 pre 70 case and looks OK to me but I'm no expert. Built top ends before but fancy full rebuild.
Would this be a good start for a 1776cc. Also would single relief be ok as can send off to be full flowed machined or will an external filter via oil pump be sufficient.
Guidance please
Sent from my SM-A127F using Tapatalk
Ive done 1835 cc single relief case motors. It'll be fine as long as the case being used is in good condition
thanks for reassurance, can you tell from pics where I need to be looking, how can I tell if its had a few regrinds or if journals need tlc as to me looks reasonable nick. Also what did youy do with oil system.?
1 - 9 of 9 Posts
