i presume you mean 1 of the 6 large nuts that holds the case together? I think its an M12? try and M12 nut?im sure its only standard nut with a washer behind it.
but small headed type hence 17mm socket required.Laurence Fletcher said:The big ones are M12.
correct, but you don't need to use the small headed ones, standard 19 mm A/F M12 thread nuts will work on the bottom 3 studs, (on the top 3 they will catch on the tinware).Bugsy_Malone 666 said:but small headed type hence 17mm socket required.
