you may need an engine support (jk do one) most bays of this age came with a type1 (beetle) engine one mount is different
Depends on the case. If you have a universal AS41 case then it should fit with little problem. If you don't have a universal case then an adaptor will be required that effectively attaches the engine support bar to the oil pump.
