1 - 2 of 2 Posts
Have fitted a a new 1600 engine with the
same engine code, but when the new engine is fitted. The flywheel sticks on
the gearbox housing.. Is their anything i can do to remedy this???? Flywheel
is exactly the same as off old engine.
What car is it on ? Is it the original Gearbox ?Where in the bellhousing does it catch ? Is it the gear teeth on the outside rim of the flywheel ? Are you 100 % sure it's the same flywheel as the one previously fitted ?
1 - 2 of 2 Posts
