Why have you disabled the choke and how have you done it ?
It sounds like an air leak.
Check list -
New gasket between carb and manifold.
Blanking plug still in place on carb body.
No open pipes on carb or inlet manifold - everything should be either connected or blanked off.
Check the rubber vac hoses to the air filter and distributor carefully - the rubber often cracks underneath the cotton braid.
Manifolds bolted to head with new gaskets (preferably card ones if it's a twinport - the tin gaskets can leak.)
Tinware trapped between manifold and head meaning the manifold can't seal fully.
Washers dropped over the inlet manifold studs before fitting the manifold end castings (Voice of experience)
Hose (jubilee) clips used to seal the rubber manifold boots instead of the proper VW ones - Ordinary clips pinch the rubber where they join and can cause air leaks especially if overtightened.
Use a length of flexy pipe to listen around the engine for the sound of air being sucked in. Fuel pipe is good but you can use hosepipe. A better method than using WD40 IMHO.
