Not sure where to put this but thought I would try here in case any one else has the issue.
The Bugjam web page has a form to fill if you wish to have this years tickets transferred to next year but there appears to be a fault in the form. If you fill in the required fields without entering a ticket ref number (it states not a required field), it throws the following error:
292905
This is the form here:
I tried it with my ticket ref too and it threw up a code that then disappeared, so I dont know if my application went through.
Administrator
Hi dude,
Can I suggest you email: [email protected]
Give them as much info as possible, name, address, original ticket reference, etc.
I'm sure they will sort it/confirm if it went through - and be thankful for the heads up about the glitch/fault.
Good luck. :)
