1 - 10 of 10 Posts
I'm buying this engine and was hoping if someone could give me and idea of the expected power output of this spec. thanks!
1914cc
ITS UNLEADED CHROMOLY HEAD STUDS
69MM FORGED CRANK
ENGLE 110 CAM
SCAT LIFTERS
MAHLE PISTON KIT TEFLON BUTTONS
PORTED AND POLISHED HEADS
FULL FLOW OIL SYSTEM
BIG OIL COOLER
EXTERNAL OIL FILTER SETUP
EMPI BREATHER SYSTEM
NEW TWIN 40 WEBBERS WITH FILTERS AND LINKAGE
anyone got any good guesses? :D
StefFreak said:
what heads and size of valves ect??
:hangloose
sorry all the info i have is above, i'm after a rough estimate to ensure i'm making the right choice for my split!
seems a nice choice for a bus as youv got a mild cam which isnt to leary, which is abad thing in a bus when youv got all that weight
also youv got the cooling which is perfect for a split as those air vents dont give much air flow
id say ABOUT 100-115 mark
:hangloose
:hangloose
excellent that'd be spot on then, any chance it'll run under 18 secs in an empty panel van??? ;)
What ratio rocker gear are you using? What ignition system are you planning? Compression ratio is a big factor too...........
1 - 10 of 10 Posts
