1 - 12 of 12 Posts
putting my engine back in after sorting the valves out on my bug, but having problems getting the splines to match up and cant push it all the way in. any tried and tested tips, im at a bit of a loss :crazy:
This works if you are alone:
Shift in gear (any gear).
Handbrake on (or tie wheels down so they can't spin).
You can apply a very light coating of lube to the splines.
Push engine in and at same time very slowly turn the pulley.
It should plop right in.
This assumes that the clutch disc has been centered when you
installed the disc and that the shaft splines aren't buggered.
Have you got the back of your bug jacked up while your trying to do it?
Sorry if i'm stating the obvious, but if you have, are you dropping the engine onto the shaft at an angle matching that of the car. If your not, then that will be causing your problems. I had this the first time I swapped my engine.
Now i jack up the front of the bug, so the body is level and the engine can be rolled into place on a trolly jack.
EdA said:
i tried the crank pulley, i think im just not coming in square, quite hard to gauge the angle of it. my fan housing is still on, is it easier without?
I don't think you'll be able to replace the fanhousing once the engine is in place.
Discussion Starter · #12 ·
sorted, well sort of, the splines in the clutch were a bit chewed so it wouldnt mate properly with the input shaft. no doubt did it when i took the engine out, might be a little bit more careful next time, mind i have realised the clutch is contaminated with oil, so gunna replace the input shaft seal as well, a small silver lining :)
1 - 12 of 12 Posts
