I'm trying to fit my weber idf filter baseplates the ones for the CB crossbar linkage but the studs that the stacks were bolted too are simply too short especially if the stacks are supposed to fit on top of the baseplate.
How hard is it to remove these studs? Its on a set of 44's.
Cheers:)
Mike
I had exactly the same problem on mine.
If you put 2 of the nuts on the stud thread and tighten them together with 2 spanners, you can use one to wind the studs out a bit, they need to be tight so as not to just unwind together. This worked for mine, there seemed plenty of thread and they stayed tight enough. Once the filter top was on they tightened down even more.
Hope this helps
Thanks for that:). I'll give it a go, theres no loctite on them is there?
don't think so but might be worth adding some as there will be less thread after
