1 - 8 of 8 Posts
hey guys,
my flywheel oil seal leaks a bit and its gettin on my tits
iv tried a silicone and standard one, both leak... iv fitted both of them the same - to fit just inside the case... is this what im doin wrong? should they be flush?
what sort do you guys use?
my engine will be out soon and i wanna stop it leakin!
mabbo
hello moby,
thanks for the reply... the engine is about 15,000 miles old now, maybe more... 20k.
its a hi-po motor - new crank, used case and flywheel though.
ill try a genuine vw seal next time... and ill fit it flush just incase.
thanks mate
mabbo
i also never had an original seal ever leaked on me....
what is the history of this engine? you just got it?
1 issue is that the seal could have been removed wrongly...i.e prying with a screwdriver and that could have damaged the seal seating area PERMANENTLY.
Superhero
the engine (1955 turbo) was built about 3 years ago me and mabbo and he has driven all the miles. No damage to sealing face that I am aware of.
I think it's more a case of which seal (original sounds best) and how far to push it into the case. Mine is pushed in so the chamfer on the seal is past the chamfer on the case. not all they way to the bottom. Its OK.
Pat can get some v good ones through work it you want to give him a bell
ey up people... sounds like im gonna hav 2 get a genuine vw seal and ill fit it flush. iv tried one of those seals off pat dude... i think thats whats in there now :(
mabbo
seems ok on the bug but then she's not racing ;) :)
1 - 8 of 8 Posts
