Can anyone give advice on the best front shocks for a lowered split that will help to eliminate tyre rub?
I'm running an adjutable beam (albatross adjusters) and dropped spindles, BRMS and 50 profile tyres. I get quite a bit of rub if I drop the beam below its highest setting.
Using a shock absober to keep the tyre away from the arch is not a soloution to you problem! If they fail as they probably will due to you putting too much strain on them your tyres will hit the arches!
sounds like you need a narrowed beam!!
Yeah, I realise it's not a solution in isolation, but I am simply after firming up the front a bit. The beam and spindles are doing their jobs correctly, but I would like to go a touch lower but need to stiffen up (fnar fnar) in order to do so.
You say you've got 50 profile, I guess that's 195/50? You may need a narrower tyre to tuck up, inside the arch ie 135/70, 145/65, 165/50, 175/55, 185/55 or even drop to 195/45.
Volkszone Forum
