1 - 16 of 16 Posts
Limebug has just completed a fully bolt on air ride kit for swing axle and IRS Beetle's/Ghia's
4-Valve, 100% Bolt on, 6 Point Rear Brace System.
Price: £1895.00 Complete
Kits consist of:
1 of Any of these Front Setups:
K&L Front T1 / Ghia
Ball Joint Front T1 / Ghia
1302/ 1303 Front Air System (available at additional Charge)
1 of Any of these Rear Setups:
Rear Swing Axle (Medium Axle) T1 / Ghia
Rear Swing Axle (Long Axle) T1 / Ghia
IRS Single Plate T1 / Ghia
IRS Dual Plate T1 / Ghia
1 of Any of the following management options:
4-Valve Manual Paddle Valve Kit using 5 Gallon Steel or Alu Tank
V2 Digital Management Air Pressure Sensitive Management (available at additional Charge)
E-Level Ride Height Sensitive Management (available at additional Charge)
I-Level Upgrade to IPhone or Android Control system (available at additional Charge, only compatible, if already purchased E-Level System)
£1895.00
http://limebug.com/product/view/2586/t1-complete-1950-79-swing-axle-air-ride-kit
http://limebug.com/product/view/2585/t1-1950-79-bolt-on-rear-swing-axle-air-ride-kit-211
T1 1950-79 Bolt on Rear Swing Axle Air Ride Kit:
T1 & Ghia Rear Swing Axle Air Ride Kit 100% Bolt-on, No welding, No Bodying Off The worlds only fully bolt on rear air ride system that not only allows you to run full air ride while utlising twin bellow 2500lb air bags, and competition gas shocks, but also can be fitted without splitting the shell from the chassis of your beetle/ ghia. The perks of the Titan Engineering rear air T1 Bolt on Air Ride system are:
- Control your ride, simply using our manual paddle valve or V2 digital systems, the kit allows over 7" of travel meaning no problem with steep driveways, speed bumps, cats eyes, potholes, getting on and off a ferry etc.etc
- Titan Six-Point Brace System, our kit utlizes a unique design using the shock towers for lateral loading and using pre-load bars to the gearbox mount along with a cupped mount around the torsion tube housing. This system allows pre-load and left-right and front-back tweaks. This system prevents "creep" and chassis movement by adding strength to the existing structure.
- Lay-it-out, no compromise drop it to the deck design, you may wonder if the design of this kit restricts upper and lower travel, the answer simply is no. This kit will drop the spring plate (if notched or stepped) to bottom out metal-metal on the upper chassis bump stop with the rubber removed. Trust us that is low.
- Save your Fulcrums and Bearings, Commonplace faults with static lowering your vehicle is chewing up fulcrum plates and wheel bearings from oil starvation. Air ride gives you the ability to adjust the ride height to give you the best of both worlds, slam it for the shows, daily drive it in absolute comfort.
- Bolt on also means Bolt Off, So keep hold of your old parts, if you have enough of the car or want a new one, sell the kit on or transfer it, no need to re-buy.
- Upgradable by design, our system is designed and configured to work with Manual paddle air systems, solenoids and the V2 Digital Management system. -
- Straight out the Box, All kits come Powder Coated in a thick hard wearing Gloss Black, all hardware required to fit to any stock T1 or Ghia is included. The only optional extras we offer are notched spring plates which we do recommend but are not essential in order to fit the kit.
- Simple Installation, the kit can be installed in a day with no issue with moderate experience, and basic tools. Garage fees are reduced significantly. Note: Early vehicles will require late axle end castings in order to fit, rough guide is pre-60 vehicles (Split case gearbox style) with adjacent lower shock absorber end castings. If in doubt please call first.
- Air Management: 4-Valve Manual Air Management. Utilising a 5 gallon tanks twin dual needle gauges, air cut off switch. Our kit uses Viair 380c compressor available also as a dual kit. Fit the manual paddle gauges in the dash or glovebox. Comes with Stainless mounting plate. All gauges use 1/4" line.
£850
Bolt-on Rear IRS Kit:
http://limebug.com/product/view/2962/t1-1950-79-bolt-on-rear-irs-air-ride-kit
Looks like a whole lot of money ..... BUT as I'm in the process of doing my own on a type 3 I can confirm how much goes into developing a system and the cost so don't think it's actually that bad.
Limebug, slightly hijacking your post, (however see it as a free bump...) :)
Would you be looking at creating a system for a T2?
Looks nice. What's the price. Do I need a second mortgage
£1895.00 dude, I have put details in the description now!, sorry it was a bit vague before
How much ??
£1895.00 for the full kit, I have edited the main description to give details of all options. :)
Yes we are creating a T2 Fully bolt on Front Kit currently, it is due for completion in around 3-4 weeks. Our front kit uses needle bearings and a cartridge system we have designed so no metal on metal grinding where some options currently just use an adjuster with plates through the middle. Our design also holds laterally so you can run grease seals and means the whole front axle can't float from left to right. We also are working alongside this project a bolt on rear kit for late split and bay window. This is still at early stages though.
Do you have any pics of this in situ? Would be good to see how it all fits together, especially at the rear.
Cheers,
Jim
Pretty sure you still need the tank and compressor. It's just a management system.
Discussion Starter · #14 ·
Cheers,
Jim
Will Do Jim, for now here is the IRS kit, The Swing Axle is much the same. We are making an installation video and putting together instructions to be available shortly on our site:
Air ride
Stu_b what I mean is if I was to buy the standard kit and then upgrade to v2 digital, as you've already bought the compressor and tank. Surely it's just a case of the wiring loom and solinoids and control box.
Discussion Starter · #16 · (Edited)
£850
1 - 16 of 16 Posts
