1 - 12 of 12 Posts
I need a gear select rod for a 66 split, the entire 2 pieces if possible, from the socket to the grub screw and then from there righto the back of the van,
anyone have either section or all of it lying about?
anyone have either section or the lying about?
hi got the whole 2 off a 79 bay if it helps?
mark
07765 890696
empi pervert said:
Early or late '66?
They are different ;)
hi mate
i'm not sure as its an import, and the date is only approximated on the v5, so i'll check the chassis number when i get in tonight and let you know asap :D
jf
mark
07765 890696
hi mark,
not sure if this will fit it or not? if the '66 are different, we may find the bay is also?, hopefully empi pervert has one thats correct for the year,
If anyone can expand on this and tell me if it will fit or not?
Discussion Starter · #10 ·
empi pervert said:
Whats chassis number dude?
275023780
i need the whole gubbins from underneath now :eek:
mounting plate (the bit you bolt the gearstick to) as mine is lets say 'damaged'
the entire front rod from the knuckle back to the grub screw,
the rear rod, from front grub screw back to the rear shift rod coupling
£ waiting :elvis:
1 - 12 of 12 Posts
