:tick: :tick: just picked up a gear box that has a h code, and no space before the h , as i can only find ah and bh codes in books.
the gearbox is missing the nose cone, has reduction boxes and wide 5 pattern drums, there is no cups for bump stops on the axle/reduction boxes.
the brackets that are usually welded to the axles for brake line, is a removable bolt on style.
any ideas??????????
cheers mike. :hangloose :hangloose
TREKKER
-181
-TAHTS IF THE WHEEL BOLTS ARE M12
THAT BOX WILL BE 4.125 - IE HAVE 33 TEETH
-IF IT DOESN'T, THEN I DUNNO
OPEN IT UP ANYWAY, AS IT MAY HAVE A LSD, YOU 'NEVER' KNOW
