Fancy that, i got a box for my project and it has no prefix letter!
the number starts right at the beginining so there was never any room for a letter prefix, the number is 9332200 can anyone help explain whats inside!
Keep looking as there will be another number with the prefix letter. They can be hard to see sometimes but it will be there :)
Moby5153 said:
Unless it's an early 60's 1200.
Didn't know that :eek:
Thought these might help :)
These are the only codes I have
AA 1200 4.375 From Chassis No 0 981 810
AB 1300 4.375 Up to 8/70
AC 1500 4.125 also some 1300 from 8/70
AD 1200 4.375 Limited Slip Differential
AE 1300 4.375 Limited Slip Differential
AF 1500 4.125 Limited Slip Differential up to 8/70; also some 1300 from 8/70
AG 1200 4.375 Type 147 Fridolin
AH 1500 4.125 IRS from 8/68
1600 4.125 8/69 ñ 8/72
AK 1500 3.875 Type 181 up to 8/70
1600 3.875 Type 181 from 8/70
AL 1500 3.875 Type 181 with LSD up to 8/70
1600 3.875 Type 181 with LSD from 8/70
AM 1300 4.375 Saloon and Cabrio from 8/70
AN 1600 3.875 Karmann Ghia with IRS from 8/70
AO 1600 4.125 Karmann Ghia from 8/70
AP 1300 4.375 LSD from 8/70
AQ 1600 4.125 LSD 8/70 ñ 8/72
AR 1600 3.875 Karmann Ghia with LSD from 8/70
AS 1600cc 3.875 From 3/72
AT 1600 3.875 1303s and Cabrio from 3/72
AU 1600 3.875 1303s and Cabrio from 3/72 with LSD
BA 1300 / 1500 4.375 Semi Automatic from 8/68 ñ 8/70
BC 1300 / 1500 4.375 Semi Automatic from 8/68 ñ 8/70 with LSD
BE 1600 4.125 Semi Automatic from 8/70 ñ 8/71
BF 1600 4.125 Semi Automatic from 8/70 ñ 8/71 with LSD
BG 1600 4.125 Karmann Ghia Semi Automatic from 8/70
BH 1300 4.125 Karmann Ghia Semi Automatic from 8/70 with LSD
BJ 1300 4.375 Semi Automatic from 8/70
BK 1300 4.375 Semi Automatic from 8/70 with LSD
BL 1600 4.125 Semi Auto
DA 1500 /1600 4.125 Type 3 Swing-axle up to 8/68
DB 1500 /1600 4.125 Type 3 Swing-axle up to 8/68 with LSD
DC 1500 /1600 4.125 Type 3 IRS from 8/68
DD 1500 /1600 4.125 Type 3 IRS from 8/68 with IRS
splittwoways said:
....the (transmission) number is 9332200 can anyone help explain whats inside!...
The letter designation was dropped in October of 1965 when the last of the crash-gearboxes were produced. This was done simply because VW were then just using one box for the Type 1 so had no reason to differentiate it from any other. The letters were reintroduced at the start of the 69 model year (I thiknk) to take account of the semi-auto boxes that had been introduced a year earlier. Your number falls within that 'non-lettered' era and so would make it a 4.375 ring & pinion, standard syncromesh from approx. the 67/68 model years.
