urgent help req. please
I have a t25 1981 aircooled camper with a gearbox that it stuck in 3rd gear.cannot shift it anyhow, previously to getting jammed it whinned and graunched a bit on changung from 4th to 3rd. any advice will be gretefully received
thnx bob
That could be a clue.
If something serious hasn't happened on the gear mainshaft,
it could be a shifter/linkage problem.
I'm not an expert on these boxes, but they have had troubles
with the "side-shifting" linkage.
http://www.longenterprises.com/diagram_folder/diagramlist.htm
in particular, Diagram #10 and #15.
Haynes has a good description of that box too.
Unfortunately, there is not very much that can be done unless
the box is removed from the Van.
quite a common fault on aircooled t25 boxes is for the 3rd/4th gear hub to disintegrate - causing the box to lock in gear
My 2.0 ac box lost 4th with a similar graunch - the mainshaft bearing had come loose in the case :(
