Hello.
As from previous post I have my1970 1300 swing axel gearbox removed from my beetle. I thought while it's out I want to remove axel tubes and clean treat and have better access for cleaning the side plates.
What can I use to clean the main gearbox body ?
I will also need new gasket shims if I'm removing the axel tubes. Please recommend a replacement kit ? Will also need new oil please help on grade etc ?
Once I have all parts cleaned and degreased I shall epoxy mastic all parts and topcoat.
If I have missed anything help and advice greatly appreciated.
Thank you.
Thank you.
