gearbox. trekker engine and a 65
1 reading
1.7K views 10 replies 3 participants last post by  Bada Ben
#1 · (Edited)
Would a trekker engine fit in a 65 beetle as there seems to be a 2 in gap at the back of the engine where the gearbox seal is
#11 ·
Fitting Cylinder head tins with engine in-situ, should be possible if the fan housing and manifold have been removed. Will probably need an assistant to help line-up the bottom tins at the same time.
