my 66 beetle has decided to illuminate my little red light.comes on as normal start up then stays on.not draining my battery(regulator) wires ok and all fuses ok.light goes off after turning off at the ignition.any tricks to see if the generator is on the way out or just playing silly beggars.many thanx :incheek:
How do you know it's not draining your battery ?
First quick things to check -
Fanbelt tension.
Dynamo brushes not worn down
Wires good & tight on dynamo and regulator.
dave.
borrow a multimeter off someone
set it to volts (d.c.)
put meter across battery (black wire / -ve to earth wire and red to positive)
ignition on engine not running .... 12volts
if u have an alternator engine running at idle 13.6volts rev engine upto 14.2v
if u have a generator engine running at idle the voltage should rise a small amount rev engine voltage should rise up say 0.5volts BUT it should rise
hope this helps
many thanx to you both.problem sorted loose connection on the generator.oh happy days.... :incheek:
