i have a karmann ghia which i foresee getting cut up :(
but the chassis is IRS with balljoint beam :hangloose
now I think that if i cut out ( the probably rusty) ghia floorpans and weld in some bug pans the chassis will serve well in my bug for good handling etc ,
then i wont have to irs my bug swing axle chassis- which I plan to do anyway?
is this the case is the bug and ghia chassis the same bar the floorpan with?
or is the chassis destined for the big drag strip in the sky too?
Floorpans are the only difference.
If you use the KG chassis for the Bug, remember that the registration number stays with the chassis.
Is the KG body really that bad ? It seems a waste, to raid a KG to upgrade a bug.
G
After visiting a Ghia owner recently I can safely say that the front of the floor pan is different to a Beetle.
The beetle one angles back from the frame-head to the sills through roughly 45 degrees. The ghia pan turns through 90 degrees - like the Trekker pans do.
yeah i know about the chassis numbers- :incheek:
the ghia has rusty sills inner wings wheel arches etc, i have it in the for sales underrusty rhd ghia project
http://www.volkszone.com/VZi/showthread.php?p=2897391#post2897391
yeah a rhd car! a 73 square bumper car.
economically i think a rust free car and a dash swop would be better
thanks hairy yeti, like i say i would change the floorpans, as long as the spine is the same
Check out MIBs project oval (find one of his posts and there is a link at the bottom)
he's done exactly what you are saying
