Hello, I have a 66 model ghia coupe I’m putting back together. Have a strange indicator issue, effecting the offside rear lights but not the near side. When the ignition is on, the 3 pin indicator relay clicks but no indicators, if you indicate left both front and rear are bright and correct. Same when indicating right except the front indicator is not so bright. As soon as the ignition is on, the offside brake light lights. The braking system is not fully installed so no master cylinder switch for the brakes is connected. Looking at the wiring diagram the brake light and indicator power is on the same fuse? Ind relay is new so not sure what is happening or whether they are unconnected issues? Wiring is pretty much unmolested from new so no obvious short circuits. Appreciate any help. Cheers, Tony
