1 - 10 of 10 Posts
If you do buy one from GSF, check it has the adjusters, it may sound stupid but I had a look at a beam in one of their stores. The adjuster plates and bolts were missing, as far as I am aware these are not available separately, the salesman didn't know about aircooled sparts so as far as he was concerned that was how the beam is supplied. Naturally I did not buy it.
Most of the 'off the shelf' adjustable beams are from the same factory (puma), any of the usual suppliers should be able to supply you with one, ie ssp/heritage, big boys toys, cool-air, machine7 etc.
As said above - they are the same puma beam as sold by most other places, but usually a bit cheaper than most.
Height wise, dropped mine to it's lowest and struggled to get the jack under it - at more sensible height now
1 - 10 of 10 Posts
