hiya, if she is getting to be wider than she is long and her pelvis is starting to get wide too then she is probably preggers. seperate them now as they can mate again straight away as soon as the little ones are born.
age is very important, how old is she generally if they mate after the age of about 8 - 10 months then the pelvic bone can fuse causing natural birth to be difficult.
keep her somewhere you can keep an eye, ie indoors and by the bed at night as this is usually when they will give birth. if she seems to be in labour with no sign of babies she will need a vet so get the number of a small pet vet now.
the babies come out running, they will be eating solids within an hours of being born, but will still feed from mum, you need to seperate at about 6 - 8 weeks.
they are pregnant for about 60 days and you will feel the babies moving inside her from about 45 days on ish!!
if she births one straight after the other she may not pull the sack from one of them so be prepared to help out. she wont mind you touching them if she knows you well, but if she or the babies need help, help dont worry bout anything else. she should be over and done in about 30 minutes if she is much longer than that then she needs help by a vet.
hope this helps.
http://www.ahc.umn.edu/rar/MNAALAS/GPig.html
nykxx
hope this helps.
nykxx
