:incheek: 65 split panel van, tried fitting standard 12v relay to get the indicators working no joy at all.hazard lights ticking away happily tho.swapped old 2 pin relay(wagner) from 4 ways onto the indicators hey presto they work,now new relay won't work the hazards, anyone any idea where to get a 2 pin or is there another way round it?bus is 12v by the way. :incheek:
You can get 2 pin flasher relays from vehicle wiring products here:
http://www.vehicle-wiring-products.co.uk/VWPweb2000/relays/relays.html#gen443
One interesting thing to note is a '65 panel van won't have had hazard lights originally. It was very common in the 70's/80's for people to buy "hazard light kits" which tapped into the existing wiring loom so I can only assume it's been fitted with one of those kits. Two pin flasher relays aren't really designed to operate the hazard switch. A "quick fix" would be to remove the Hazard light switch as it's not actually an MOT requirement for the age of your van.
:incheek: many thanx for the info. shud've said it's lhd.yanks bein yanks had them as standard.it's a lovely red shiny lens tho. :incheek:
:incheek: thanks for the link and your wiring diagram will have another more informed bash at it in the morning. :incheek:
If the worst comes to the w.... I'll play stupid and deny all knowledge again.
AH! Yeah the US one had them as standard.
One of the Angel VW Club members had a problem with their US imported splitty as they couldn't get a replacement flasher unit anywhere and ended up having to order one directly from the US.
