I want to replace my headlining, as it has all come a bit ripped and scabby. Is it easy to switch from having a 1300 full headlining, to a 1200 only top bit?? is it a good idea? or not??
When you take the headlining out you will find that it leaves behind the padding down the B pillar and around the rear window. This will have to be removed and re painted. You will probably be best putting a 1300 full lining back in unless you are planning on having it resprayed to...
Also check this post as i have been having headliner problems myself.
http://www.volkszone.com/VZi/showthread.php?p=2961462#post2961462
well, i'm getting the whole car re-sprayed so. It wouldnt make much difference. :) It's just the fitting etc.
