1 - 19 of 19 Posts
Hi,
I have two heater leavers, one on each side of the handbrake. Can someone tell me which one does what? I seem to have hot air coming out of the floor, but they do not seem to turn off?
Cheers,
Matt.
they operate your levers on the left/right of your heat exchangers,which are obviously not connected.
Ah, I have not checked the floor on the passenger side ... at least its stuck on heat at the moment what with frost this week! Cheers for the replies
Well hot air and some exhaust fumes, so need to keep the window open, or I start to get a little sleepy!!!
SOREHEED said:
get that sorted yesterday ;)
How??? I get it the other way - if my windows are open then exhaust fumes get waaaaaaay worse. When they are closed then its fine! Heaters arent hooked up so might have something to do with it?
mat_at_home said:
Hi,
Cheers,
Matt.
noooooooooooooooooooooooooooooooooooooooooooooooooooooo
there not heater leavers there ejector seat leavers passanger n drivers ,
if yove tried n nothing works there prob disconected ,
YOUR VERY LUCKY THERE DISCONECTED :crazy:
Discussion Starter · #10 ·
Yeah, got so much to do on it and so little time, got 4 wings, 2 doors, 2 bumpers, bonnet, wiper motor, running boards, Pertronix Distributor with elec ignition, 8mm leads, and Pertronix coil, and loads of other stuff on order .... also getting 4 new tyres tomorrow .... getting a bit skint now, and its to dark to do much work in the evenings.
so what should they do? i pull the levers and nothing much happens. paul picked the bug up in january and said they worked then.
what lever does what?
Discussion Starter · #14 ·
Ahha, thats good, I will see if the rear ones work / control .... cheers,
I had the same problem - couldn't turn the heat off. I was getting gassed with exhaust fumes too. Flap had rusted away, so it was a new heat exchanger and problem solved. :)
alfietinker said:
I just found the original manual for my car and it says the left controls the rear footwell heating and the right controls the front. :)
ooooooooooh. right. so leave the left alone and just use the right. i hope.
Iain_M said:
If you want to freeze your passengers, yep.
lol. the back seat isn't for passengers, its for luggage. and shoes.
1 - 19 of 19 Posts
