Check with a test lamp/multimeter at the fuse, fusebox connection, and connection block behind the n/s engine bay insulation panel. The number plate light originally comes from the o/s sidelight wiring.
Thank you Laurence you are a legend!Laurence Fletcher said:8 amp (usually white body), on those lamps
