hi can any1 help me
462 Views 4 Replies 3 Participants Last post by  Speedy Jim
Hi just got a 66 splitty 1.6 twinport , the problem is she doent like ticking over ! after a short run shes fine but if i switch her off and on again she wont tick over even if shes hot please could any1 help is it the carb? oh it also back fires when coming off the throttle and smells abit rich sorry im all new to the aircooled
The carb will often flood the engine after a hot run.
Caused by the high temps in the engine bay which
can vapourise fuel from the carb bowl or, worst case,
actually boil the fuel out.
A float needle valve not sealing tightly can also cause this.
Besides checking the carb, see that the engine bay is
tightly sealed around the engine.
"Backfire" as you describe is usually caused by small
leaks in the exhaust system.
reply
Hi thanks what do you mean by engine bay sealed? the tin wear isnt fittint that well would that do it? also only starts if i press throttle down cheers
Is the carb & dizzy correctly tuned?
Are all the bolts done up tightly - fannymould to heads, carb to fannymould
Also as Speedy Jim suggests, is the exhaust "A" ok?? - No holes??
I am in Sussex too & can look at these for you if you like??
If the engine tinware isn't perfectly sealed, the engine
will draw in extra hot air from the exhaust system underneath.
That will raise the engine bay temp above what it should be.
