Edit:
Spec is:
64mm crank, dynamically balanced with flywheel, clutch & pulley,
85.5mm piston/Cylinders, shortened to 1200 cylinder length. Pistons clearanced for short stroke.
C25 cam with HD single springs & lifters,
9:1 static compression,
Power pulley,
26mm oil pump & full flow cover,
Deep sump,
External oil filter
Ported 1600 twin port heads
Std. 1:1 Rockers (will update to 1:4 one day
Twin DRLA40 carbs
Doghouse fan and oil cooler
Std. SVA Distributor for now.
Its been run in on my test stand, just need to set carbs up properly.
Lot of work for probably not much HP, but it will be fun and its been a good leaning experience :lol:
Spec is:
Power pulley,
Deep sump,
External oil filter
Twin DRLA40 carbs
