How do you remove.....
564 Views 4 Replies 4 Participants Last post by  71Dormobile
the inside door handle and window winder handle of an early bug (1955)???
As usual the search engine is not working so I'm having to ask for help once again.
I want to remove the handles so that I can take the panel off and get the quaterlight windows out so that they can be rechromed, but I'm having difficulty figuring out how to get them off as I can't see any obviuos screws like on the later models.
They are held in by a pin which goes through the handle, where it attaches to the spindle in the door. Push the plastic ring and door panel into the door, (away from the handle), and you'll see the end of the pin. push it out with something like a long thin punch, (a drill bit works, but be careful it doesn't shatter).
Thanks Laurence, I'll give it a whirl....panic over now...I almost snapped them off.
the search engine on here is working fine :confused:
no matter you got sorted anyways :)
cheers
paul :D
Don't snap em off as you'll find original oval parts especially the winders etc ££££££ to replace use the pin tap it out and away you go.......
Once removed the quater light will be held in place with a bolt inside the door itself and also a self tapping screw up inside the door itself. To get at this you will have to remove part of the window seal felt guide as the screw sits behind this
