28 7/16 inches long axle with long spline(type1 68>)
27 11/16 inches long axle with short spline(type 1 67)
26 11/16 inches short axle with short spline(type 1 61/66)
Thats wots written in my note book anyway.
Sorry to Hijack but do you know what the length of the tubes are too, from gearbox to spring plate mounting face?
I've measured a 67KG one to be 440mm
A 66 Splitty is 460mm
A 63 type 3 is 400mm
(I think thats it. I got the figures at home but I'm at work now so its from memory)
Anyway, question is, what is used for a splitty straight axle conversion? Obviously it needs to be close to 460mm
For a straight axle in a split bus you need a short axle tube end casting with a long axle.Does that make sense?Is that what your asking?
You can buy axle tubes ready to go or use a modified short axle tube from 61/66 bug (it needs to be lengthened at the gearbox end so the weld s are inside the gaitor).
