1 - 19 of 19 Posts
Having a clear-out of T2 parts stored in my garage for at least the last 10 years! All parts either NOS, good quality usable second hand OE (have thrown out all the rusty/broken tat!) or anything 'new' has been discounted from the current VWH/Schofield price. ALL PHOTOS BELOW LIST.
Free to collect from rural Kent or will package & take to Post Office for postage price. Feel free to contact me with any questions or offers...
211 953 051/052 - OE VW HELLA Front Indicator reflectors, S/H, heavy quality pressing, galvanised back plate, good condition, reflectors fine (polish up nicely), pair - £80
211 945 237 J - OE VW SWF Rear Light reflectors, S/H, heavy cast pressing, reflector area needs polish but OK, OE quality brass/fibreboard connectors, chrome plating peeled on lip, pair - £100
211 941 039/040
- NOS VW HELLA T2 Splitty Headlamp units, complete, original quality, VW boxed, pair - £500
211 941 039/040 - VW BOSCH Lens T2 Splitty Headlamp units , complete, S/H, worn/rat-look chrome rim but no-rust, reflectors VGC, 1 has surface rust on outer housing inner, pair - £180
211 941 039/040 - VW HELLA T2 Splitty Headlamp LENSES ONLY, RHD, S/H, slight scratches & minor chip to 1 side glass only , pair - £90
217 957 023D - OE VW Speedo, 80MPH, S/H, completely original & unmolested, VW production stamp 6.66, normal slight condensation rust inner lip - £100
211 957 801E - NEW Speedo cable, VWH repro , '55-'67, 2060mm, LHD - £8
211 707 335 - OE VW Rear Bumper Irons, S/H, heavy duty originals - surface rust only,1 slightly dented on inner legs of one but no mods reqd unlike repros, pair- £60
211 609 701F - NEW Handbrake cables, '64-'67, GEMO German quality, pair- £32
OE VW Cab interior central blank plate, VW original (where ambulance fan normally goes) - £30 SOLD
211 845 121 - NEW Front windscreen seals, Alan Schofield, quality rubber, pair -£36
211 941 039 VW HELLA T2 Splitty single LHS Headlamp complete, RHD lens, S/H, slight scratches but no chips to glass - £80
211 863 711B - OE VW original Cab Floor mat, '58-'67, LHD, used condition with a few small splits/tears in usual places which could easily be superglued - £50
BN4 Eberspacher petrol heater, 6V complete, original & unmolested, working when removed from '64 ambulance - £200
221 845 301x - OE Split Side window Pop-out with AMBULANCE glass, S/H, ORIGINAL VW (white half opaque strip) from '64, rust to lower section join only - £200
221 845 301A - OE Split Side window Glass, set of 4, S/H, 5mm width Original VW Sekurit/Durit, 2 have slight scratches, 1 has good OE rubber, '60s - £160
OE Rear Axle bump stop, S/H, VW original, rubber great condition, no split/tears, almost as new - £30
OE Complete 1500 Gearbox, axle, reduction boxes, hubs - from '64 ambulance, 20k miles only when removed - £400
211 953 161/162 NOS OE VW Hella Front Indicator fish-eye lenses, '62-'67, pair - £100
212 953 161/162 OE VW Hella Front Indicator fish-eye lenses, S/H, '62-'67, rims overpainted silver, slight nick to 1 lens only, otherwise no cracks, pair £30 SOLD
211 953 165A NEW Front Indicator fish-eye rubber seals, '62-'67, WW quality rubber, pair -£25
211 945 241 NOS OE VW Hella Rear Light Lenses, all RED, '62-'67 & early Bay, pair - £120
211 945 245 NEW Rear Light lens rubber seals, German quality rubber, '62-'67 & early Bay, pair - £34
211 941 073 - NOS OE HELLA Reversing Light unit, panel mounted, inc. seals, 2 available, each - £60
211 611 067/070/047 NEW Brake cylinders Splitty complete set '63-'67, 2xFRL, 2 xFRR, 2xRR - VARGA - £50
211 698 237C/537C NEW Brake Shoes, FR + RR set, German quality Pagid/Jurid - £46
211 955 425 NEW Wiper Blades, silver, repro Alan Schofield, pair - £14 SOLD
211 955 407 - NEW Wiper Arms, silver, repro Alan Schofield, pair - £32 SOLD
261 829 565 - NEW Church Key, original steel, German - £6
Louvre Window, OE, excellent condition, no rust, glass excellent, from early Bay, but may fit later (?) - £100
113 837 205A - NOS VW HUF OE Cab Door Handle, '55-'60, non-chromed, inc. 2 genuine HUF Keys, 4 available, each - £100
113 016 051 C - NEW WW Sperrwolf Repro Shift Lock Kit (ZVW36) - for pre '67 T1 or T2 (Split needs quick shift adapter) - £50
113 016 051x - OE VW Sperrwolf Shift Lock S/H, with Logo, LATE version inc. ignition lockout (complete mechanically but needs iginition switch) - post '67 T1 or Bay - £80
OE VW Complete Wiper Motor Assembly, S/H, 12V, 645mm, excellent condition, unsure which year but defo Bay - £100
NOS 6V Bosch Accessory Relay, (85-86-87-30/51), 6V, boxed, each, metal/fibreboard for that complete period look under the dash! £30
NOS 12V Bosch Accessory Relay, (85-86-87-30/51),12V, boxed, each, metal/fibreboard for that complete period look under the dash! £20
211 947 125A NEW Interior Light Lenses,'50-'67, German quality repro, Alan Schofield, 3 available, each - £6
211 857 305 OE Dashboard ashtray, S/H, Splitty, usual rust inside but solid - £8 SOLD
OE Exhaust pipe, S/H, Splitty '62-'67, surface rust only, welds rock solid - £20
OE early T2 Splitty Oil Bath carb filter setup, S/H complete, inc. mounting bracket, vgc only surface rust - £60] SOLD
117 711 115A NEW Gearstick boot, German quality repro, Alan Schofield - £6
211 405 371A NOS QH Ball joints, Bay '68-'79, boxed from '80s, pair - £20
211 415 671 OE Horn centre push, S/H, Black, Bay '68-'79, no cracks or scraches just slight ageing wear, vgc - £10
CREATIVE ENGINEERING Split Bus IRS conversion kit - includes weld on arms, fittings, instructions - need spring plates, swing arms from CE or donor - £100
Beetle EMPI Wide 5's/ OE Steels & Deep Oil Sump also available on my other listing:
http://www.volkszone.com/VZi/showthread.php?t=823564
Can I have;
Thanks. May be able to collect but post might be cheaper then fuel cost..pm or reply with price posted?
CREATIVE ENGINEERING Split Bus IRS conversion kit - includes weld on arms, fittings, instructions - need spring plates, swing arms from CE or donor - £140
do you have any more details on this?
Hi,
Depends where you're driving from I guess!
For those items, Postage is £10 1st Class signed for (2nd class only 90p cheaper), so £124 total. I can get them out to you today if you need.
Hi mygod.
Yes, it's that kit, but minus the spring plates - which I just realised makes the components I have cost £150 from CE anyway, so you can have them for £100. They are all new & unopened.
You can either get the spring plates from CE or use donors from a 68-69.
Discussion Starter · #12 ·
Hi mate,
Sure, can you bear with me for a couple of days? It's located in a barn at my Auntie's farm that I seriously need to get time to get over to and take photos!
A couple of Beach buggies are there too that I want to list ha, ha...
Cheers,
Simon
Haha cheers for the heads up...... I didn't read the date..... it came up at the top of the items for sale feed.
1 - 19 of 19 Posts
