1 - 20 of 75 Posts
...what sort of things would you include in it and why?
It can be anything and I mean ANYTHING! As weird or as wacky as you like.
I understand saying you can have anything you like no matter how weird or wacky on VZi is like opening the floodgates - so don't worry about it and don't hold back! ;)
Personally the big thing I would include would a built in Fan unit and some form of Ceramic heating element to give the heating a helping hand.
Im waiting for the "but if its all fitted correctly the standard heating should work"
Well Ive never had one thats worked yet, and anyway the Fasty is running J tubes cos replacement exchangers are a bit thin on the ground.
front fog lights
reversing lights!
Do you mean simplicity as in the layout of switches and warning lights?
I'll agree that is very simple, although the rat's nest that's usually behind it is anything but simple IMHO!
Switch and lamp ayout is fine, but yeah if the dash wiring (71 bay) was neater I wouldn't complain.
Run everything off leisure battery except for starter / ignition.
I am working on something like this - watch this space :)
central locking would be lovely. :D
Interesting that simplicity is the watchword - I'd love to see more simplicity in my wiring loom, but then my dub is a T4 and it's a bloody birds nest of a mess back there :(
Discussion Starter · #17 ·
modern fuse box
OH YES!
I know Clarkson says he likes his standard fuses but I've had no end of hassle with them - the aging of the contacts, the bloody things breaking off etc etc.
The first thing I do on a rewire is remove the stock fuse box and replace it with a blade fuse box.
I'd go for an uprated headlight circuit so better lighting can be installed and a power spur at the rear for additional accessories.
Moving to fusebox would be a bonus, it kills my back trying to get under the dash so I've got it hanging down further now so I can get to it, it also stops the water dripping on it that leaks in :lol: What about also changing over to blade style fuses would be easier for my fat fingers to handle
Other than that, it seems to have pretty much everything covered. Maybe some provision for better/more reliable earths?
Pretty much how I'm doing mine - but to do it I'm having to run patches through the factory loom and it's sub-optimal in the "tidy" department, purely because the rest of the loom is such a sealed box and cable spaghetti.
1 - 20 of 75 Posts
