Just a thought!
If i add another indicator then the timing changes doesnt it?
Is there anyway of adding another one so that the timing of the flashing is unchanged?
Mike.
You will be adding an additional lamp on the Left side and one
on the Right side?
You might experiment first. The flasher may not object to a
small additional load.
Otherwise, source a "heavy duty" flasher intended for trailer duty,
or use 2 relays (one for each side) to serve as repeaters for the
new lamps.
