1 - 8 of 8 Posts
Has anyone fitted irs to split bus. bus boys kit or creative give me the word on whats good and bad thanks Paul
ive fitted the CE kit, looks more work, but i my eyes more 'heavy duty'. pm me if you need any of the info/bits.
Im not a fan of the CE kit I didnt want to hack the arse end out of my bus I used 68/69 rear hubs CE adjustable spring plates and harry harpics shortened A arms with fully adjustable bolt on clamps (now welded).
And my frame horns are intact.
Aide
you dont have to use the adjutible springplates by CE, normal 68bay ones are fine, in my eyes anthing that could possibly rotated in a load way thu the susupesion on the van should be splined, like the ends of the springplates, those 'clamps' you bolt on the torsion bar housing dont look as hevy duty as weld on ones or the CE kit
Those 'clamps' that I have bolted and welded onto the torsion tubes are significantly stronger than the stock bay set up.
Bolted on vehicle ,4 wheel tracked then welded ALL the way around!
1 - 8 of 8 Posts
