IRS gearbox side seal _ easy to replace?
378 Views 2 Replies 2 Participants Last post by  Swanny
I mean the one that seals around the drive flange keeping g/box oil in the 'box!
I know that when the CV joint is removed and the grease cleaned away there is a plastic cover in thhe middle of the flange but I don't know what's under it (circlip?) Does the output flange withdraw without the gearbox internals falling into a pile inside the casing?!
Ant
This should help you suss it...................
The output flange slides off leaving everything else in place.
Thanks, I may attempt it this weekend.
