Option 1 (Recommended): Don't do it - Cost : £ 0.00 :D
Option 2 ( Simplest): Dropped Spindles - Cost around £280, no other mods required.
IMHO, adjusters are just too troublesome, needs lowered shocks, and castor shims, (more expense), and although they go seriously low, the geometry is not right, and the ride quality is appalling. ;)
Option 1 - Not recommended under any circumstances! :D
If running adjusters, you only need shorter shocks if you're want less than about 3 or 4 inches of ground clearance, otherwise you'll probably be ok. Castor shims are only really needed if you have rake (i.e. front lower than the back). As for ride quality, it's a bit firmer but I certainly wouln't describe it as appalling unless something's done wrong. (See my signature).
