is it ok to use a beetle master cylinder on a 67 splitscreen ..i was thinking of mounting the brake fluid pot behind the seat...thanks
i got a 67 splity m/c with the pot on in the shed
where are you?
i was looking at putting a beetle one on so i will have duel circut brakes rather than a single circuit,thanks v much for the offer,oh i am not far away im in wrexham.... :hangloose
oh! hi!
im sure iv read about it being done
i dont see why not but i think you need to keep to a drum brake m/c?
or is it only relevent when you go to disks?
Check the bore sizes first, I think the T1 cylinder may have a smaller internal bore than the T2, which would tend to give you more pedal travel and "softer" brakes.
Perhaps a bay window dual cct cylinder would be more appropriate.
I know that beetle cylinders are 17mm dia, and brake drum equipped bays are 22.5mm dia, not sure about splitty cylinders though.
I would only consider using one the same diameter as stock, or perhaps slightly larger.
