My milage counter has stuck. Anyone know what may be the problem. The speedo is working so am a bit stuck
If you take the speedo out and take the back off you will see the pin with the mileage numbers on, on the end of this shaft there is a small gear, that small gear sometimes splits and then just spins on the shaft.
its a fiddly job but you can knock the shaft out clean any grease of the gear and superglue it back on
its a right pain lineing everything back up to reassemble but very doable
